Hi
Is there a high capacity battery available for the N95, anyone with any info?
Hi
No, currently the only battery available is the one the N95 ships with.
azzy wrote:HiIs there a high capacity battery available for the N95, anyone with any info?
I seem to be having the same problem with battery life on the N95 that I had with the N80ie and that is that I'm charging at least once every 24 hours.
OK, I know I'm still at the "playing with it" stage but all the indications are that the BL-5F is no better than the BL-5B. Also, as per the N80 thread, to get a better battery life/more power it would seem that the battery would need to be larger and therefore not fit in the phone. Several people tried batteries that claimed to offer more life for the N80 off the net, but to no avail. I have completed the 3 * 16 hour charge and discharge cycles as recommended in other forums and will wait to see if battery life improves with usage, as sometimes happens. in the meantime I've ordered a spare battery.
hey! its back to the old skool nokia 5.1 and a daily charge or death!
think its spare battery and memory card purchase time!
Thanks ian for the info, if you do get some luck please let me know, in the meantime i will try and search for more info regarding the battery life.
