i hate the lifeblog application... i have a nokia n73 and all i wanted to do is to delete the lifeblog. problem is, i never found lifeblog on the apps manager!!!😡 can someone pls help? please???:frown:
someone please help me?
If it is factory-installed/built-in in ROM (Read-Only Memory), then you can't uninstall it with Application Manager, or otherwise.
If you don't want to use it, then don't (you can move it to the bottom of a submenu with all other apps your can't uninstall, either, and which you probably also don't use; PTT, Dev. mgr, Actv. keys, Modem, Tutorial, IM, Help, About, etc.).
ok, thanks... i have y-browser which i downloaded somewhere and i used it becuase there is still no fexplorer for n73. can i use it to delete lifeblog? i know there is a possibility that it's on rom, but i still have high hopes it isnt.
