N70 for VoIP via WIFI hotspots?
1 replies · 4,900 views · Started 03 April 2007
I'm thinking of buying a N70 purely for finding WIFI hotspots and making VoIP calls.
The reason being that it seems to be the cheapest phone that can do it with WIFI.
Thing is, (seeing as you guys actually own one already), how easy is it to do that?
Is it a pain in the neck to get it to use WIFI?
Is the VoIP software crappy?
Thanks guys! And I hope this suggestion saves you �$�
N70 cannot be used for VoIP in WiFi spots because it doesn't have the necessary hardware. You better go for E60, E61(i), E70, N80 if you want to access hotspots.
