Im using a nokia 6600.
N im using nokia pc suite 6.81.
my operating system is windows vista.32bit.
I have bought a billington bluetooth dongle.it came up wid the bluesoleilsoftware.
the version of it was 1.6 but in vista i cudnt instll it.so i downloaded
bluesoleil v3.0 from the net.But it needs a reg key to use it fully.i searched it over the net.but cudnt find nything.So my version is limited to 5mb data transfering in total.
If anyone have the crack or reg key thn pls help me.
My main problem is whenever i try to connect my phone wid the pc through pc suite.
The connection manager searches for my phone n it shows ma phone.But when i click next it says cannot authenticate the phone...
I have tried so many times...
I also tried with da pc suite 6.82 n the one came up wid the phone.But nothing happend.
CAN ANYONE PLS GIMME A SOLLUTION????
Btw does widcomm bluetooth driver works with billington bluetooth dongle????
I'll b so thankful if anyone can gimme a sollution.Pls help me.
Pls Help with pc suite foe 6600
PC Suite 6.* versions do not work at all with the Nokia 6600. The 6600 needs its own PC Suite: http://europe.nokia.com/A4143896
As IVT Bluesoleil did not exist (was not on the market) when the PC Suite for the 6600 was made, it might not work. Infrared should in any case.
