Hi,currently the mobile games that i saved from the pc for my nokia 3230,after i transfer it to my MMC 512Mb.When i am about to open it,All the games didnt appear on my nokia 3230 screen?
Why is that happened actually?
What type of files does Nokia 3230's support for the download Games?Is it .jar .mbm. .sis ??
I'm really confused because..Usually i copy it the files such as .jar to my MMC Folder...> SYSTEM....> Temp (and i paste my files of .jar in there) . Is it correct or wrong?
I'm just confused actually..
1. where shall i locate the files at?Which folder in MMC Card?
2. Which files do Nokia 3230 Support?is it .jar / .sis / .mbm / or others?
Easiest, if you use the PC Suite Application Installer and then when you install, on the phone choose whether to install the app in phone memory or the memory card.
The 3230 is an S60 2nd Edition Feature Pack 1 phone, and it supports S60 2nd Edition apps in .sis files, and it also supports MIDP 2.0 Java apps in .jar files.
Women... Installation files are .sis or .jar and this means you have to put them on any folder which is visible on your file explorer. Select the file which you want to install and it will ask where to install (phone or MMC). ONLY AFTER INSTALLATION you will be able to see the application inside the menu.
Another way is like N/A suggested.
What is the PC Suite Application Installer?
Huh?i really have no idea..what you guys said..Im really confused.
I jus download it the game from the game website and i got the download games as example.. nfsu2.jar ( it only few bytes)..it jus my way..i jus cut the file and paste onto my memory phone..(without using bluetooth or infrared )
as normal as i do for my wallpaper..i got most my wallpapers from the server.i jus did like this..it can easily open..why do i need the PC Suite Application Installer?For wat?How to do it?Do i need to transfer using the bluetooth or infrared?or etc?can you explain to me..I am really confused and blur at this moment...Please??😮 😮 😮 :redface:
OK, so you don't know anithing about S60, that was the problem.
Any program comes as an installation package, either .sis, or .jar and you need to install this after transfering the files to the phone (from PC or from download). How do you do this? Go to the folder in which you pasted the file and simply open it. The installer will then ask you where do you want to install the file - phone memory or MMC. I suggest to use the MMC because the 3230's memory is quite low. Wait until the installation is ready and then the application will appear in the main menu (after about 5 seconds after installation end).
i have a nokia 3230 and i came apon to this website where they give this application called Chord Master and its a .sis. When i try installing this program it says file corrupt. What do i do? I aslso install this bible thing on my fone and its a .jar or .jad file but neither works on my phone. PLEASE HELP!!!!! THNKS SO MUCH!!!!!
Perhaps you got the sis file for S60v3. 3230 haves alot of trouble with jar files.
