Just had to do this for email notification chris
Nokia N95 and N95 8GB Product codes [Debranding]
Hi, I've just finished debranding and updating my N95 8Gb from UK Voda,(Now using GiffGaff) My question is this:-
I used code 0549487 this produced the following results
V 35-0-001 RM 320 N95 (01 01) great to a point.
I now have push-to-talk option (never had that before) I also notice I now have annimated icons
However my problem is that now the multimedia key doesn't work anymore and I cannot access the Ngage games folder.
Am I missing a piece of software, or have I got a more serious problem???
All other functions are fine.
Any and all suggestions & help welcome
Cheers Inthought
I've have reinstalled the same software update, it took about 20 minutes, and now all is well again.
However I did do two things differently, I left the GiffGaff sim in this time (previously I had used an old one from 3) and also When it came to restoring user info back onto the phone I ommited my SETTINGS all other stuff was put back. And.... 'touch-wood' all is well with my baby.
Hope this helps someone
imnew wrote:i have this n95 with product 0548364i am using version
v 31.0.0.17
16-12-08
as i have seen many n95 other product codes sets are updated to v 35.0.002.
why there is no update for this product code .and can i flash another latest version n95 on my phone , will it harm my set ?
it is not in warranty , so should i do it ?i want to use India version , can i do that ?
can anyone reply on this ?
I too have same problem. My N95 product code is 0547699. I want to change product code to 0548299 to upgrade my N95 to V35 with APAC2 language pack.
Can I do it wthout damaging my phone?
Please help.....
HELP!
I did debranding on my Nokia N95, and installed V35.0.2
Everything seems fine, except my phone crashes & restarts once everyday. Earlier I thought it happened while browsing internet, but recently I have noticed that it will restart even when it is idle. I guess its some memory overflow issue which is causing phone to restart daily. Please help me with the solution :frown:
