Hi, I'd like to know if the Nokia Music headset HS-20, AD-41 works well with the N73 (not music edition). I can't see why not except for the fact that its not listed as compatible on Nokia's site, so I'd like a bit of reasurrance before I buy one.
Also I'd like to know how comfortable it is to use if anyone here uses the headset on a regular basis. My main concern is the fact that the earphones can be easily disconnected from the 3.5 mm connector in the middle. Is this an issue?
Thanks a lot
-Natan
It does work, its just a regular pop-port type connection.
As for sound quality and comfort, everyones experiences with headphones are totally different, what is comfortable for me could be excrutiatingly painful for you.
I use the AD-41 with my N73ME and it works great. However, the HS-20 earplugs that come with it are very lame, so I personally use A pair of Creative EP630 earphones which are superb 😃
I have also successfully used the AD-41 in conjunction with a Belkin Tunecast II FM transmitter so I can use the phone in my car using the head unit.
Ok thank you guys!
I'm off to buy one tomorrow.
I dont think the music controls on the AD-41 will work on a regular N73.
Dr Tran wrote:I dont think the music controls on the AD-41 will work on a regular N73.
Yes they do. I have one and all controls work fine.
Good to know then
I have a regular N73 but upgraded the Firmware to the ME. Would the HS-20 AD-41 work?
Works fine on my upgraded ME phone 😃
Got the AD-41 today but failed it get it working properly. None of the controls on it would work and when I press the button underneath the Nokia logo, it makes strange noises. Am disappointed...
How strange. Mine works fine. Could possibly be a faulty unit ?
Everything works but the controls.
I might re-install the firmware though. It's been weird lately.
Yes, worth a try. It should just be "Plug & Play" with all controls working fine. I sue mine for my earphones and also in my car via an FM Transmitter.
Got a feeling it might be fake. It looks tacky and about to fall apart. It did work for a very brief 5 mins tho.
Where did you buy it from ?
A website off kelkoo.co.uk
