gps
1 replies · 1,881 views · Started 05 April 2007
hi there
iv just ordered a nokian95.its due to be delivered on the 12th.its with 02.can any one help me as im wondering to use the gps does it charge you as in wap/internet.or is this built in the phone and its free to use.
iv been reading up on it quite a bit now,but no where explains if you have to pay to use the gps. i await your reply thankyou:con?
By default, you will have to pay GPRS / data charges to download maps of where you are. However, as Nokia recommend if you don't have a flat data tarrif (such as WebNWalk from T-Mobile), you can download the maps to your computer and then copy them to the memory card in your phone.
Visit www.smart2go.com for more info.
