Hi ! my name is andy this is about nim's file, when i use NOKIA Multimedia converter to converter into nim's file after useing VirtualDub-1_4_11 it seen never work. it just show Mmconverter has caused an error in ACC.DLL and MFC42.DLL why ? what had i done wrong can anyone please help me ? holp to hear from you guy soon
THANK YOU VERY MUCH !
& HAPPY NEW YEAR TO YOU GUY . ALL THE BEST !
what's happen !
I have this problem on my PC as well so any advice on this very annoying problem would be very much appreciated 100%! 😞 😞
Does the converter crash when you convert stuff that hasn't been through Virtual Dub?
YES :x
All my video file been through Virtual Dub, but when i convert mp3 to wav it seen no problem 😞
u're using a Pentium 4 PC, aren't you?
Multimedia convertor doesn't work on P4 processors, it just converts Audio files.
Hope they will make it work in the next MMC.
Regards 8)
:roll: Yes ,now i know what happen. thank you guy ! all the best in the year 2003+ 2..............
[quote="Special"]u're using a Pentium 4 PC, aren't you?
Regards 8)[/quote]
I have a P4 laptop and it works on that, so it isn't a P4 problem, or unless it doesn't work on P4 PC's only which is a great shame 😞 😞 😞 😞
I do wish that someone could come up with a solution as it would make my life a lot easier. :-? :roll:
[quote="N9210"]Does the converter crash when you convert stuff that hasn't been through Virtual Dub?[/quote]
[quote="4u2nv"]YES :x[/quote]
Decide yourself...
[quote="4u2nv"]I have a P4 laptop and it works on that, so it isn't a P4 problem, or unless it doesn't work on P4 PC's only which is a great shame
I do wish that someone could come up with a solution as it would make my life a lot easier. [/quote]
What are you on about with ??????????????????????
Pro MMC works on my P4 laptop but NOT on my P4 PC! :x :x :x
Now I got it..
[quote="andyg1039"]Hi ! my name is andy this is about nim's file, when i use NOKIA Multimedia converter to converter into nim's file after useing VirtualDub-1_4_11 it seen never work. it just show Mmconverter has caused an error in ACC.DLL and MFC42.DLL why ? what had i done wrong can anyone please help me ? holp to hear from you guy soon
& HAPPY NEW YEAR TO YOU GUY . ALL THE BEST ![/quote]
I have that porblem too!!!!
do you already know haw fix that!!??
regards
:roll:
it's been a year since i'am useing 9210 till now 9210i even i call nokia help desk. WORSE !( they know even less about this) i still wish someone can solve this problem 😞
I have the same problem!!! 😞
probably problem is with some codecs like xvid or so ....i have the same problem unsolved...any ideas ?
I also have this problem and it is annoying, but it is not a P4 problem as i have an Athlon desktop and PIII laptop which produces the same error...
That was me, forgot to log on 😮ops:
