PC Suite for Nokia 7650 sucks!
2 replies · 1,989 views · Started 03 January 2003
I just bought a brand new nokia 7650 but i'm nog satiisfied at all with the software. I used to have e nokia 8310 and for that ons the software was just great. You could keep alle messages, all contacts from your phone.
You also could edit you phonebook and all other applications like calendar and stuff. With this software i only can take a stupid backup The only thing good on the software is the image transfer tool.
Are ther other PC suites for the nokia 7650 in development wich can do the same as you could with the great normal version of PC Suite.
Or can u use or patch older PC suite versions (like 4.81 wich i had before) so it supports the nokia 7650.
Can someone help me please?
Thanks already,
Christophe.
There is coming a new version of PC suite for 7650, lets hope its better.
Its the only one that works.
You can sync with outlook and edit all there.
When would the new version would be coming and would it be for free? or do we have to pay some $$$ for it ?
