I installed SkyeCaller on my Nokia E65, now and I can get it uninstalled? Not in the file manager, everytime I recieve a message, that I can't delete the program or if try to delete the file. Somebody knows what I have to do.
I have already uninstalling a view programs who was not a problem.
Somebody knows more?
Thanks,
Ronald
The Netherlands
Wirelessly posted (Nokia E70: Opera/8.01 (J2ME/MIDP; Opera Mini/3.0.6560/1662; en; U; ssr))
Where did you install it to, is the file a java program?
Hi, this is the file: "SkyeStream.SkyeCaller.v1.01.S60v3.SymbianOS9.1" who is a normal Nokia Application Installer-file.
I have installed it with the Nokia PC Suite thru installing application, and the program comes automatically by > Menu > Installed programs on my Nokia device.
Did you install it on your phone or on your memory card?
If I go to menu > installations > applications manager
then I see these two applications:
Skeyfault
Skyecaller
If a try to delete this [options>delete] I get the message "Can't delete this application"😡
Is there a good working Symbian Explorer program, that I can download?
