I wish i can connect to net from i fixed line!
11 replies · 3,081 views · Started 03 January 2003
How to connect to internet from a fixed line?? :cry:
i've tried eInternet .. but everytime i try to connect, the phone is rebooted :x
plz guys, post Settings for eInternet, I'm using a Laptop with windows XP, connecting via infrared or cable.
i want to connect to net using my Laptop/PC modem
[quote="Special"]plz guys, post Settings for eInternet, I'm using a Laptop with windows XP, connecting via infrared or cable.
i want to connect to net using my Laptop/PC modem[/quote]
Me 2.
Any help on this?
Special actualy did it using eInternet. eInternet will work on most computers, be sure to use Mocha ppp connection.
Only problem you might experience lies with the bad Mochappp server which you would run on your desktop pc. This Mochappp server has problems when your pc has more then 1 IP.
yep, how it works:
you install Mocha PPP software on the pc, and then connect your 9210 to yor pc and surf over whatever internet line available (even over a full network!)
If I find the time I'll write a review about this 😊
Check eInternet from Psiloc website.
There you'll find instructions to use Mocha PPP(also the link) with eInternet 😉
