image transfer
16 replies · 2,553 views · Started 03 January 2003
I'm not able to download screen images of dope wars to computer with ir which I took with screen taker . all other images taken with cam I've downloaded succesfully
I'm guessing cos no-one knows the answer. Can't think of a reason myself either.
Can you be more specific about what error you are getting, where you saved the pic to..etc?
You seem to get teh most uncommon questions 😃
OKay, for starters, what do you get when you try to transfer the image?
for expl.
all the pictures I take with my cam are stored under images.
and I can transfer them to my comp using pc suite. but when I take some screen shots with screen taker they are also stored in images folder on 7650.
but pc suite can't see them so It's like they don'texist on the phone. but they are storen along with normal pictures and wallpapers wich I transfered via IR
[quote="pandemonium"]for expl.
but pc suite can't see them so It's like they don'texist on the phone. but they are storen along with normal pictures and wallpapers wich I transfered via IR[/quote]
You can send any file (include pictures) from 7650 to PC direct by using SeleQ. You can select to send via MMS, e-mail, Bluetooth and Infrared.
You dont need eFile or SeleQ to do that.When you are viewing the thumbnail of the picture just press options and send via infrared.
Sometimes the most hardest stuff you wanted to find are obviously infront of you! (really pisses me off when i'm looking for a pen or something for like 10 mintues then it turns out to be in my hand! :P 😃)
right...like the other day I took my 760 in the right hand and yelling on my grlfrnd .... :evil: where the hell is my gd 87 (cuz I'm using 3 phones)
and after 5 mins i figured it out that I was tlking to it at the same moment
