After trying to upgrade the nokia N80 firmware, and getting upgrade complete from the nokia software updater, I tried rebooting the phone and keep getting the " phone start-up failed. contact retailer message". sometimes the phone wouldn't even turn on but the led would blink... is there anyway I can fix this or go back to previous firware version? the phone is not functional in anywa:frown: y... Even when I try to hook it to the USB it sais that is non recognizable. What can I do to fix this?
Any feedback is very much apreciated...
Hani
try the hard reset if its turning on even abit (most are pure bricks)
failing that take to a NSC
this is becomming common now, i no off 3 bricked phones from this upgrade in the last 2 days!!
makes me wonder about the next upgrade and is i worth the risk!!
You sure the phone is charged cause one time my phone was dead and i was trying to boot it up and i got scared cause it wasnt booting up and just showing a blue led blink. You would need phoenix to reflash it if in fact it is bricked.
thanks for your feedbacks... yes phone was fully charged... how do we hard reset??
Thanks,
Hani
Hani76 wrote:thanks for your feedbacks... yes phone was fully charged... how do we hard reset??Thanks,
Hani
"Turn off the mobile device. Then press and hold �3″, the �Green button� and �*� - Turn on and keep holding untill the phone fully restarts. If successfully, you�ll be asked to reenter the date, time, city, etc. Its tough but it works." (http://thinkabdul.com/2006/10/13/tip-format-codehard-reset-nokia-n80/)
hard reset didn't work...any other suggestions?
Re-flash your phone with phoenix.
There's a guide on the forums. I killed my phone a few firmware revisions ago and managed to bring my phone back from an even worse condition that yours.
EDIT: Done the legwork for you... http://www.allaboutsymbian.com/forum/showpost.php?p=285582&postcount=54
That's my post in an older firmware update thread. Have a read of the whoel thread too but hopefully with all the software installed you'll be able to follow the guide well enough to recover your phone.
Hi again...thanks for all ur feedbacks... I am trying to download phoenix and the dongle cracks but some of the links are expired.. .can anyone send me active links to download the following?'
Phoenix 2004 Dongle Fix
Phoenix 2006 Fix
v4.0623.0.41 Firmware
thanks!!!!!!!! a lot!!!!
Hani
Same here - can someone send me the links, and I guess the 0707 fw.
NSU failed part way through mine. Arrrghh. Now just have an "unknown" malfunctioning USB device (which I guess is a basic bootstrap for flashing)
hi, prev i had upgrade from n80 to n80ie using phoenix and it work successfully
With the new firmware provided by nokia, i tried to upgrade it through nsu and half way through it hang. Currently i am unable to power it on or even tried using the phoenix to reflash it does not work.
Anyone can provide some advise? Thanks
