Face distorting software on the 6600
7 replies · 2,757 views · Started 09 April 2007
A couple of years ago I had some software on my 6600 that allowed me to take a picture and distort it (usually faces) to the amusement of everyone who tried it. Unfortunately I can`t remember what it was called. Does anyone know what it was called, if its available for the N80 and if so where I can get it.
Thanks Sugarbabe that is it. I`ve done a search and it is by a company called Cognimatics but the site doesn`t mention whether it works on the N80
Unless they've specifically got a version for the N80's (pretty nonstandard) screen resolution then it's not going to work out-of-the-box as it were. However as long as you don't mind a bit of distortion you can do a little tweak that will rescale the midlet to fill the full screen.
If you do a search in this forum for something along the lines of java screen size you should find what you need.
Thanks everyone, just got back from my hols so haven`t been able to reply. I`ll give all of your suggestions a try.
I have 2 programs on my phone facewarp & photorite, i think photorite does a much better job of changing the picture.
Pete
