Hi there,
Is it possible to update my N70 S60 v2 firmware to v3 firmware via the Nokia Software Updater? , currently the firmware is dated 2005
Madds007
Hi there,
Madds007
No.
It's a different O/S.
It's like wanting to "upgrade" Windows XP to Windows Vista - you can't, you need a fresh installation.
madds007 wrote:Hi there,Is it possible to update my N70 S60 v2 firmware to v3 firmware via the Nokia Software Updater? , currently the firmware is dated 2005
Madds007
I think you meant firmware version 3, maybe? The latest is 5.0638.3.0.1 from 18.09.2006 and yes, it is possible. Just enter your product code on Nokia's software updater website and you'll see instantly which is the last FW version.
