Hello..can anyone tell me how to remove the date fom the display of my N91?
N91 Display
there is no way as far as i know
can copy ur complete z drive to ur hard disk and mail it to me using xplore software. in turn i can help u enhancing ur loudspeaker volume
Lazarus77 wrote:Hello..can anyone tell me how to remove the date fom the display of my N91?Choose some other profile than "General", and the profile name will be displayed instead of the date (if you want it removed from the standby screen). You can also name/rename a profile to, e.g., your name, or something, if you like that better.
You can also in the Settings app change the default screensaver to text, for example (if you don't like the date/time there either).
You cannot remove the date but instead you can write anything there. For instance, you can put your name or number in that particular place. Go to Tools, profiles, options, create new and punch the characters that you want to appear in place of date. You may further personalise your settings and use this new profile.
N/A wrote:Choose some other profile than "General", and the profile name will be displayed instead of the date (if you want it removed from the standby screen). You can also name/rename a profile to, e.g., your name, or something, if you like that better.You can also in the Settings app change the default screensaver to text, for example (if you don't like the date/time there either).
Hello, guys
I have the opposite problem - I would like to display the date in every profile not just General with or without displaying the profile name. Is it at all possible in active standby. (BTW, I am using N95 8GB, not N91, but I suspect the OS is the same)
