my nokia n80 is 3 branded soo it uses the 3 firmware but if i follow the giude to flash my firmware back to the noka generic firmware will i still be able to use my 3 sim card ? also is it worth changing from branded to generic ??
new firmware
andrew.w wrote:my nokia n80 is 3 branded soo it uses the 3 firmware but if i follow the giude to flash my firmware back to the noka generic firmware will i still be able to use my 3 sim card ? also is it worth changing from branded to generic ??
Yes you will still be able to use your 3 simcard in the phone.
Its worth changing if you see some advantage in it.
1 last thing if you want the simlock off thats different to using generic firmware..
