N95 + WPA Mixed Mode / 802.1x
3 replies · 10,106 views · Started 10 April 2007
has anyone managed to get their N95 to connect to a network using 802.1x authentication with EAP-PEAP? got it to connect to other networks and the net seems to work fine but it doesn't seem that happy connecting to 802.1x networks at the moment. time to crack out the debugs 😞
jman200x wrote:has anyone managed to get their N95 to connect to a network using 802.1x authentication with EAP-PEAP? got it to connect to other networks and the net seems to work fine but it doesn't seem that happy connecting to 802.1x networks at the moment. time to crack out the debugs 😞
I have the very same problem. Anoyone knows how to fix this ???
raymasky wrote:I have the very same problem. Anoyone knows how to fix this ???
tools / settings / connection / access points / choose AP / WLAN security mode / 802.1x ..
go back then into WLAN security settings / wpa/wpa2 = EAP .. EAP Plugin settings EAP-PEAP .. this is the part I leave to you guys .. since there are so many variations
This link might give you a hand getting your ssl stuff sorted ..
https://blogs.forum.nokia.com/view_entry.html?id=412
Let us know how you get on!😊
Make sure EAP-PEAP is enabled and at the top of the list.
Ok, common stuff to setup EAP-PEAP.
You must choose the correct Authority Certificate, you can't guess this... ask your sys admin. For EAP-PEAP you don't generally send your own certificate.
In the 'User Name in use' dialogue choose user defined
In the User-Name field enter your username (if your using this on an international roaming network enter your username as user@institution) this will be used as your outer identity.
Next press the right directional key, that'll switch you from settings to EAPs, make sure only EAP-MSCHAPv2 is enabled and at the top. Go options edit, enter just your username no@institution (this is your inner identity) then enter your password.
Everything should now work.
Most people don't notice the pesky EAPs tab or know which inner encryption type to select.
Sorry to revive a very old thread, just this is the top hit for n95 802.1x on google.
