3250
4 replies · 3,714 views · Started 10 April 2007
hi new here,
ok so this is my 3rd 3520 iv got through insurnce, i cant stand it y can it hold like no songs iv got to delete pics and bids n songs to fit new ones on the other day it would put on average mb song on with no pics left and vids to take up memory it still gaev me , memory low delete song data
WHERE CAN I DELETE DATA , BECAUSE IV EMPTYED EVERYTHING
why o why didnt i buy a sony erricson
any help and dnt wana buy bigger memory
but it dosnt give me that option it says save to phone or mem wen it sent but i can never actully get itto do it
have u tried hard or soft format on ur phone.if not try it else get the flashing done from nokia care centre .i hope this may resolve ur problem
it does tht becoz wen you snd stuff to it, t goes on the phone memory first. all you need to do is go to messages. then go to options. scroll down you should see the settings menu, enter it and go down again enter the 'other' menu. there is a txt 'memory in use' go there and change it memory card, and that's all n need to panick.
