nonstandard contacts numbers?
1 replies · 1,422 views · Started 11 April 2007
hello,
i just picked up a nokia e61 and flashed it to the latest firmware. after syncing my contacts from outlook, i was dismayed to find that some of the numbers in my contacts book do not work.
the numbers are in the format "+1 (626) 123-4567, 1234567890, 1234567890", to dial an international number using a phone card. this used to work on my old windows mobile based devices. i was just wondering if there was a workaround for this.
best,
charles
[QUOTE=cheez80;307029]the numbers are in the format "+1 (626) 123-4567, 1234567890, 1234567890", to dial an international number using a phone card."
Is it the 'pause' functionality you are missing? If so, you can put the character "p" or "w" in the phone number fields. These might be able to replicate what you are trying to do
