Video and AD-41 headset issue
3 replies · 3,003 views · Started 11 April 2007
Hello I'm new here and had two questions regarding my N73.
Firstly, when you record videos from your phone and play them back, they don't appear to completely fill the screen.
I'm quite sure that they used to before, but have noticed this since I put my own encoded videos that there are two small bars on each side on the videos I take on the phone.
Is this normal? as im quite sure its not, and if so how can I correct this please?
Second question is regarding the AD-41 music headset. I get a crackling noise from it when playing back and skipping through tracks. I thought maybe the headset is faulty so had it exchanged but its still doing the same thing. any ideas?
Thanks for any help or advice in advance,
16vAK
Any help to the video issue would be appreciated. Just to add this is in the high quality setting so in MP4 format.
If someone can confirm whether mp4 videos taken on the n73 can play completely full screen, that would be great too?
Mine doesn't fill the full screen either.
If I just play it back straight after record it shows a bar at the bottom and top of the screen. I can pause it and tell it to continue in full screen but even then there is still a black border all the way around the video.
If I go to the gallery the black border is there as well. It's as if the screen is widescreen while the video is only 4:3.
Regards
Thanks for clearing that up mate.
Before reading your reply, I decided to backup and re-flash the phone. But its still not playing the videos fullscreen. I thought it played fullscreen before but I guess its normal then.
Anyone have any ideas on the crackling noise issue with the AD-41 headset?
