N91 Gallery Crash, Bang, Wallop
4 replies · 4,676 views · Started 11 April 2007
Hi All,
I have had my N91 for a couple of weeks now and love it, however, I can take pictures on the phone, but cant view them, the phone says 'connecting' and has a progress bar, but then nothing..........
I have had to remove battery to continue to use the phone, is there a cure for this problem, running firmware v2.20.008 N91(02.01)
try a soft format by typing *#7370# on phones stand by screen or a hard reset by powering the phone off and powering it on by pressing * + 3 + green button simultaneously
Hi
Thats weird, it sounds like you are connecting to the PC or over the air. Can you explain in steps the problem?
Example:
Open camera Application
Take a picture
Close Camera App
Then I open Gallery
then....
music
Zaaka wrote:Hi All,
In Nokia N91 support page appear that thing is common and you must leave the phone alone until it finishes. After that the access to Gallery will be much faster
