Problem with programs on new memory card
1 replies · 2,303 views · Started 11 April 2007
Hello
I have a problem with the programs on my new memorycard. Yesterday I have bought a new memcard for my Nokia N73 and I formatted the memcard. I made a back-up in Nokia PC Suite(latest version). After that I restored the new memory card with my old data. Now is al my data on my memcard, but my N73 doesn't recognize the new programs. I don't see them in the application folder. But when I go to the application manager, I see all the applications and it says that they are all installed.
The biggest problem is that I can't use the programs, because I can't find them.
Does somebody know how to solve this???
Thanx😊
hello, what you need to do it back up your info on your card, re format and your card, and then instead of using the backup facility to transfer the info, you need to manually install everything again....sorry!! but that is the way!! hope it helps.:icon14:
