I've installed Nokia PC suite 6.83.14.1.
It backs up my contacts, and file manager sees the phone and card contents quite happily. So that part is working well.
But when I go to the application installer, it says that 'the contents of the currently selected phone model cannot be shown by this application'; both on the phone and the card.
And Nokia Maploader refuses to recognise the presence of a card likewise. I see that it requires the phone to be in 'mass storage mode' - but no trace of what that is in the help screens. As I've said on another thread, I can't get maploader to download to a cardreader either (yes, I've used maps once, and the card has a directory structure on it, so it is ok)
Any ideas please?
Phone not recognised
Now, even though I have downloaded the maps directly to the card using a cardreader, the card is not seen through the usb cable and pc Suite, nor as I said the application installer.
Has anyone been successful using the application installer over usb?
Alastair wrote:'mass storage mode' - but no trace of what that is in the help screens
I removed the memory card from my N95, inserted it into an SD adapter and plugged it straight into a HP PC with a card reader built in. I then used Maploader to directly copy to the card.
So I've no direct experience of the USB connection.
However, when you first connect your N95 to a PC you will be presented with various options on the N95 screen itself such as PC Suite, Windows Media, Mass Storage, etc. Hope that helps.
F
That was the key! Thanks, ffcphone
In Tools-Options-usb-usb mode, choose data transfer.
THEN maploader will work! it doesn't work in PC suite mode!
And it's not called 'mass storage mode'
Glad you've cracked it. "Data Transfer" - it's all coming back to me now.
F
