Orb
1 replies · 2,000 views · Started 12 April 2007
Hi all
I'm alittle confused about the Home server and Orb software.
Ive installed both and can get the N95 to see the server and connects fine.
But how can you transfer files from the PC to N95?
Also when using the Home server and you select a MP3 it plays on the PC not the N95. Can you get it to stream to the Phone and play there?
Whats better ORB or Home server program?
Cant you get ORB to stream across the internet to your phone?
With Home Server, you cannot stream music from your PC to play on your N95. The N95 acts as a remote control allowing you to access files on other devices. What you can do however is copy music from your PC to your N95. Just highlight the file on your N95 and select Copy to Phone (or Memory card) from the N95's options menu.
I don't know anything about Orb though, sorry.
