FileNote for Nokia Communicator 9210(i), 9300(i) and 9500
Advanced File Manager with macros/plugins and file description capabilities
Copyright Edo - 2007
Features:
- Two pane highly customizable file manager, like Norton Commander
- Extremely fast and driven both by keys and joystick (folder up, folder down etc...)
- Dynamically resizable windows with 5 font sizes, 3 font types etc...
- All window elements can be colorized (saving & installing skins...)
- File management functions: Copy, Move, Delete, Paste etc...
- Files sorting (name, date, size) and sort cycling separately for each pane
- Advanced file description feature (multiple lists, search, go to...)
- File/folder extended properties (incl. UIDs).
- Multiple files rename tool
- Multiple files properties editor (date, time, atribbs)
- Synchronize folders tool
- Mark/filter files by (multiple) patterns
- Compute CRC32 file checksum and compare files
- Send (multiple) files via e-mail
- Advanced folder bookmarking
- "Open with" function with ability to assign multiple programs to same file extensions.
- Export function (folder listing and file description listing)
- "Recent files" (Document, Sheet) - undocumented Symbian feature (EPOC relict)
- Browse and manage "Inbox" files
- Memory reclaim tool
- Access to RAM drive E: for full file management
- Advanced Activity log - record all actions (save, browse, add to etc...)
- Basic set of viewers:
Raw text viewer (ASCII, Unicode and binary)
Hex viewer (both hexadecimal and text)
MBM viewer (save and extract bitmaps)
- versatile Macro panel with max. 4 tables (each with 27 slots) which can contain
shortcuts to plugins (macros), documents and programs with assignable hotkeys.
- Advanced Macro library providing more than 100 functions for writing plugins
to FileNote or general macros. FileNote provides an interface to filesystem via plugins (macros).
Easy to write user plugins using provided plugin templates.
- Lots of ready macros/plugins available: HexEditor (fully featured), Decompiler (OPL), Find, Compactor,
FreeCrypt for FileNote (crypt & decrypt files), Compare files, Calendar etc...
Download from here:
http://forum.i-symbian.com/cms.php
Extended preview:
http://forum.i-symbian.com/filenote-extended-preview-t1095.html?t=1095
Author: Edo
