my nokia sim free E50 will not accept tomtom mobile 5 installation. i have 1g micro sd put in. just says not su[pported. any ideas wat the issue is?
E50 issue
You're best of contacting TomTom. The installation / apps should start automatically when you ahve the memory card in the phone.
hollauyi wrote:my nokia sim free E50 will not accept tomtom mobile 5 installation. i have 1g micro sd put in. just says not su[pported. any ideas wat the issue is?
I thought that Tom-Tom introduced S60 3rd edition support only in its version 6. Are you sure that Tom-Tom lists the E50 as a compatible phone for version 5?
