What SIP client can we use in the UK for VOIP calls via a wifi connection?
Does Skype work yet?
The SIP Client is built into the phone. You can use any SIP service with this. One of the easier to set up ones (the provide a Wizard for the phone) is truphone.com, if that doesn't suit you might try gizmophone.com
Skype does not work. The 3 version that runs on the N73 would work fine on the N95 though, but this isn't true Skype.
Ok thanks
I've installed truphone and will see tonight via wifi
Whats wrong with skype on the N95?
How come its not real skype?
Is there a download link anyway for the N95?
Many Thanks again
:icon14:
The Skype wont work unless you are on the 3 network. Its not true Skype because it actually routes call via a 3 number (i.e. its an ordinary phone call). Thats not bad, but is of course limited to the operator.
Ive setup the truphone on the phone
Do you have any experience of this?
I've got a number for the truphone now, I take it when your out and away from the wifi network it would direct the call to the mobile?
