I tried putting maps from nokias MapLoader onto my N95, i dont have a memory card and heard that its possible to load a map onto the phones internal memory. The map im trying to load is only 12MB, but maploader doesnt recognise my phone even though its blatenly regcognised by the pc suite :S Ive read somthing about the phone having to be in mass storage mode but seeming as i dont have a memory card it says "no memory card availble, cannot access mass storage mode" any ideas? cheers!
N95 maploader problem
Make sure you load maps prog gram first the nexit. Then when connecting usb cable it should give you choice to load as Mass storage device instead of pc suite.
i cant go into mass storage mode because i dont have a memory card. im wonder how its possible to store maps on internal memory then?
just me in the world that has this problem then? lol
Just you in this world with no memory card....
Mass storage mode only allows access to the memory card (not internal memory).
The only solution i can think of is, load the map onto a memory card in the normal manner,then copy it off the card onto the phone.
or just download them OTA 😊
maploader is sucking for me at the moment anyway - can't download any maps. think the servers must be getting a battering or they're down...
ordered a memory card 3 days ago still waiting for it 😞
