Connection error?
2 replies · 5,411 views · Started 12 April 2007
Just a quick question does anyone here have a problem with there N95 not connecting to the person they're ringing the phone just says connection error but the person you ring up doesn't hear there phone ring but they have missed calls from you? Me and my wife both have the N95 and both have the same problem we are on the same network Vodaphone. The wife is pissed off tbh and is taking her's back tomorrow I was hoping for a firmware update to fix it but don't know how long I can put up with it. It doesn't do it every time though? :con?
Just so you get an answer and it doesn't seem you're being ignored, 😉 , no. My N95 works perfectly with calls.
getting exactly the same thing, display says I have a signal but when you try to make a call it just says connection error. Re-boot the phone and the signal bar disappears for a minute or so then comes back and all is fine again for a while.
What's weird is that I've had the phone for 8 months or so and only just started getting the problem.
Looking on the net seems to be a few people with the same problesm but no suggested solutions as yet.
