Hi All
I have installed Roadsync on the N95, input all the settings and follow the prompts to where it says it wants to overwrite data on the initial sync.
When I say yes, the program exits to the main applications screen (where all the other program icon are)...
Any ideas what I am doing wrong?
Cheers
Nick
You have to use the menu and start a 'Sync'... that's it...
On the other hand, there is a bug with Roadsync... when you check the mailbox, you can see a little red star, if you have new emails... but you never receive a notificication on the main display.. (the little envelope at the top right corner or on the screen saver)...
And the shame is, you cannot even write or call RoadSync or their support, even when you bought this software officially... too bad...
