😮 Sooooo..............
How's it done?
I mean the Op logo, not renaming the silent profile. 🙄 :tongue:
S.
hummmmm should i tell though or let you work it out..... :tongue:
TELLLLLLL:banghead:
its a long winded process but worth it
its a few apps together to make it work the app needs to be running it only 'masks' over the top so i phone turned off it turns off, but you can do mutiple masks and make moving ones ect
but anyway check this >>LINKY HERE<< go there about 2/3rds down click english version
good luck peeps :icon14:
bbracer16valver wrote:its a long winded process but worth itits a few apps together to make it work the app needs to be running it only 'masks' over the top so i phone turned off it turns off, but you can do mutiple masks and make moving ones ect
S.
got board done another
i do mine in photoshop by the way
my 'mask' is always blank and colour of the theme
is their a limit on how big the pic can be??
194x50
hahaha you got the same silent profile as mine, but i have an extra ! Maybe I was more angry when I edited that profile! 😉
Whenever I try this my little '3' is stil displayed behind the picture. How do I get rid of this, or do i have to cover over it??
Any advice please, and this is pretty cool app. Just thinking of something good to go in that location
right
say the one that is 001.png is what you want make a file called _001.png that is the same size ect but just black use the fie exploer you are using to drop the two files into the file on C drive and open app ect thennnnn da daaa 😃
post a pic of your effort :icon14:
will definately post a screenshot. i tried making my own and it just didn't work. The ones that come with the tutorial work, but my little '3' still displays.
I will give it another try tonight, see what i can manage.
mine did that for awhile i think a restart after all installing of programs helps alot
