Help me find out my N80 edition!
6 replies · 1,898 views · Started 15 April 2007
hello ppl i'm using a nokia n80 since july 2006 but i still don't know which editon i'm using. can any body tell me how to find out.
thanks in advanced.
m.hasan
m.hasan wrote:hello ppl i'm using a nokia n80 since july 2006 but i still don't know which editon i'm using. can any body tell me how to find out.
thanks in advanced.
m.hasan
*#0000#
cheers
Aps
DoH!!!! just noticed the post was already answered 😊
I think he talk about N80 / N80ie... Remove back cover, remove battery and read the name on paper glue inside.
But will the firmware version not also tell you which version of the N80 you are using, since the newer firmware makes it IE??
Mine was a N80 normal, now it's IE, so the sticker on the back does not tell me the correct info.
Not exactly! It still be an N80. What happens now, is the firmware from N80 is the same as N80ie.
