Internet Telephone
4 replies · 5,885 views · Started 16 April 2007
Hi guys,
on my N95 in the Tools menu (am on O2) I have this option Internet Telephone. When I open it, it doesnt detect anything!? Well rightly so, because no application is installed. So I request someone to please tell me which one should I install and how?
Cheers!
britbadboy wrote:Hi guys,
Cheers!
There are a few options but I like TruPhone. It's free and they give you �2 worth of credit when you sign up. Works really well, when you are in range of a wifi connection (either unsecured or you have the key) you can dial the number but select 'internet call' and it routes it VOIP instead of GSM. This is useful if you travel abroad as you avoid the nasty nasty roaming fees (and VOIP calls only cost local call rates as you only pay from the nearest server to the phone you are dialling!)
3Shirts wrote:There are a few options but I like TruPhone. It's free and they give you �2 worth of credit when you sign up. Works really well, when you are in range of a wifi connection (either unsecured or you have the key) you can dial the number but select 'internet call' and it routes it VOIP instead of GSM. This is useful if you travel abroad as you avoid the nasty nasty roaming fees (and VOIP calls only cost local call rates as you only pay from the nearest server to the phone you are dialling!)
http://www.theregister.co.uk/2007/04/18/voip_wars_head_for_ofcom/
http://www.theregister.co.uk/2007/04/18/n95_crippled/
;0)
