Blacklisting App
2 replies · 1,298 views · Started 16 April 2007
Hi there, does anyone know of any apps or function on the n70 whereby i can blacklist certain numbers from coming through ??
I've tried 'Best Blacklist' but its a pretty pointless app as it rejects calls after one ring. I can do that myself by hitting the end call button after one ring.
I need something that sends the call straight to voicemail so it seems as if the phone is off.
If anyone can help it would be much appreciated.
Thanks in advance.
I know others, but how they work I�m not so sure - see Blackballer, just one more.
you can try Eltima Software's Smart Call Manager. in that you can specify rules for a contacts group & set them to either be rejected or directed to answering machine. on answering machine though the call is taken, the software plays your pre-recorded message & then the caller can record his message or hang up, just like regular answering machines.
