tomtom install to n95 problems
7 replies · 8,975 views · Started 16 April 2007
hi people
first post here so here goes
i recently upgraded from an n80 to a n95 on vodafone
trouble im having is i had tomtom 6 which i bought on memory card for the n80 but the memory card does not fit the n95
i tried to copy all the data on the card via memory card reader and then paste it to my desktop with no joy
the box had a cd in with tomtom home but i cant seem to install this to the n95 memory card
is there any way for me to carry on using the tomtom from the n80 on the n95 ive just wasted half a day trying and its just not happening
is this because i bought it on memory card or does this make no difference?
please help im desperate
choppy69
N80 - miniSD cards;
N95 - microSD cards;
Just put the miniSD card on a card reader, enable to see all hidden and system files on explorer from windows, and Copy / Paste all to PC.
Put the micro SD card on card reader, and do excatly the same, but from PC to card.
hi mate
rapid reply thanks
only problem is i tried that but with no joy
what did you mean by enable so i can see all system files?
will try again and let you know the results
thanks again though
choppy69
hi mate
just tried and it was half way there when it said cannot read from destination?
might work if i copy 1 file at a time but have a feeling that would take ages any other way?
choppy69
mine worked fine, i've got to be honest, copied it all over to micro sd, and bang, just had to install the app and it was fine 😊
