If the VOIP client is missing on operator branded phone can you not just download another one? Is it not just an application?
Download VOIP client to replace disabled one on operator branded phone?
rjamesd wrote:If the VOIP client is missing on operator branded phone can you not just download another one? Is it not just an application?
Interesting proposition. I believe the answer is NO, but you could install iskoot (N80 version) and see if it works on an Orange branded N95. Let us know! 😊
dez_borders wrote:Interesting proposition. I believe the answer is NO, but you could install iskoot (N80 version) and see if it works on an Orange branded N95. Let us know! 😊
iSkoot works fine, however it is not true voip, it works by dialling a number which you are charged for, then you are connected to the number you are calling, basically you can get charged twice for instance if you ring a landline.
Wait for Fring to be released on the N95, this allows you to make Skype/SIP/MSN and more calls and will work even on Vodafone and Orange branded phones as it does not use the built in SIP/Internet Tel function.
Ratkat wrote:iSkoot works fine, however it is not true voip, it works by dialling a number which you are charged for, then you are connected to the number you are calling, basically you can get charged twice for instance if you ring a landline.Wait for Fring to be released on the N95, this allows you to make Skype/SIP/MSN and more calls and will work even on Vodafone and Orange branded phones as it does not use the built in SIP/Internet Tel function.
Thanks for correcting me, Ratkat. :icon14:
Keep the forum users informed when Fring is released.
The full sip stack is not a downloadable option.
It needs to be embedded in the firmware ....
i've read somewhere about flashing to a non operator crippled firmware? not sure on this, installing a 3rd party SIP capable client would get around this.
oh, and tried using an older version of fring - doesn't work sadly. must actually check the version instead of just blindly installing. damn you, well written software :P
