PLZZZZZZZZZ i need anti virus
2 replies · 2,318 views · Started 17 April 2007
[FONT="Arial Black"][SIZE="4"][/SIZE][/FONT]Hey guys i am so angry with my phone 😡 [FONT="Arial Black"][SIZE="4"][/SIZE][/FONT]there is a viruse init and i dont no what should i do to remove it plz guys send me a anti virus plZZZZZZZZZZZZZZ:frown: :frown: :frown: :icon1: 😊
You may want it, but you don't need it (even if you think you might), if you follow the simple advise here (don't install unknown apps/cracks):
http://3lib.ukonline.co.uk/viruses.htm
So, clean your phone by reformatting it, and stop installing bad apps (they do not install on their own).
hi!
U can use AntiCommWarrior which is specially designed for nokia 6600 kinda phones. Viruses and worms can be removed using this. U google it for the right website. Many websites give u a download.
