HELP ME PLEASE
2 replies · 1,257 views · Started 05 January 2003
i was using s compress to do my files, then the timer ran out i have over 2 mb of space conpressed (including real player) now i cant access these programs but the space is still low. when i put scompress back on it says the timer has ran out so nothing can be done!!!! what do u guys advise?
If I remember correctly you can still uncompress all apps and then remove
the sCompress. That should solve your problem. Or buy it. 😃
Its worth it.
thing is, if you uncompress and there is very little space, your phone might crash! best thing to do is but the app, it's well worth it as Jyrik said! 😃
