I wanted to know if new firmwire can fix the problem for the sound while recording videos because it is quite bad and also how long do u think it will be till they release a new fireware? I.E. (How long do they usually release it after a new phone?)
Also are there any other problems users are experiencing with the phone to do with camera (Images/Video)?
I think you must have a fault if you think the sound is of bad quality, i've owned an n93 and now the n95 and i think the recorded audio is better than the 93, it's just not stereo which doesn't really matter, (stereo seperation was never good on it anyway with mic's less than half an inch apart lol. Just make sure you got your video settings set on the highest quality setting.
No i dont own a n95 yet but planning to get one and ive seen a video with the n95 an its got a background sound heres the link http://www.allaboutsymbian.com/news/...group_test.php.
Also is there much difference between recording in mono or stereo?
And can new firmware increase the speed in which the camera loads or any other way as i have heard it takes 4-5 seconds?
