6630 headset help please
3 replies · 1,927 views · Started 18 April 2007
while my headset is connected to the phone and when someone text me the phone speaker will also rings. is this normal.. before if im right if the headset is connected the phone will not ring instead the ring will be diverted into the headset. im using latest firmware.
This is normal, the sound can be heard both in the phone and in the headset so that you can hear the sound either if you listen to music, or the phone is somewhere on the table with the headset connected.
ratza wrote:This is normal, the sound can be heard both in the phone and in the headset so that you can hear the sound either if you listen to music, or the phone is somewhere on the table with the headset connected.
can i turn it off? the phone speaker while the headset is connected?
No, only by selecting or modifying a profile in order to set the phone not to ring, but in this case you won't hear anything.
