Hi all, Is it possible to upgrade n73 firmware to latest symbian s60 os versions
(9.3 or fp2)
Upgrade N73 to Feature Pack 2
Only if Nokia officially upgrade the firmware, but they have a habit of not doing such things.
It is my understanding that you cannot (or Nokia simply don't) upgrade feature packs and OS version. Firmware updates are bug fixes, nothing else. To benefit from new OS's & FP's, you need to buy a phone that has them.
AFAIK.
You are right (as usual) Lovesign!
Been all over the web.. and sure enough you cant upgrade... not worth it really!!.. better USB2.. cute icons that move .. and support for 3.5G.... a few oter things but these are the main ones...
Do you really want to Vista on your fab N73 !!!!
Hi all Firmware updater i need ur help.. without product code can i update the firmware?:redface:
