Nothing in my Gallery section.. why?
4 replies · 1,819 views · Started 18 April 2007
Everything dissapeared in my gallery section, only the "Download Video" and "Download picture" is available. Anyone have the same problem?? How to rectify it and where can i get the latest firmware for 2007?
Phone is N80ie.
you can restart your phone.
check your memory card and which memory is in use for camera
take another pic and see if that shows
Updating latest f/w option is covered many times in this forum. Have a search for it, but you do need to have the latest version signed off by your service provider... or go a slightly more back route direction. 😎
fleng wrote:Everything dissapeared in my gallery section, only the "Download Video" and "Download picture" is available. Anyone have the same problem?? How to rectify it and where can i get the latest firmware for 2007?
Phone is N80ie.
I've had this problem a few times on my N80ie as well..and seems that (in my case at least) the problem was caused when I was using the PC Suite program to transfer mp3s/images to/from the memory card. If I'm using the phone in Mass Storage mode...no problem whatsoever.
The only way I can fix this problemo last few times was to uninstall every program that you've installed on the card, re-format it and start over again.
If anyone else has some other fix for this...I also like to hear it. Thanks.
yeah, thats a good point actually... there is a setting in PCSuite that you can have so that everytime you sync your phone, it removes all your pics.
Check that isnt happening
oh no...I forgot to mention that the pictures are still there on the memory card...it's just the phone for some reason won't recognize it.
