1.
I have problems after having 4,13 installed. Also new software was installed by a Romanian (Connex) service centre, good service! They claimed they had a newer version of the .sis files than the ones on the Nokia site. It is indeed different in size.
The error that I got is
>application AppArcServerTread
>Reason code FSCLIENT panic
>Reason number 24
It happened frequently after typing a password with Smallbase.
But now I am confused, because Smallbase does not give this error any more and works fine.
I had it also when opening a small mail in messaging.
After this error the 9210 becomes unstable and has to be rebooted.
2,
at Taksmanager a (at least for me) new piece of software appears, called BackupserThread. It varies in size (about 200K)
Cannot end that task with Taksmanager.
what does that software do?
Huib van den Oever
1. I have this same error message occasionally on firmware 4.13.
Most of the time this one appears when opening a word document or an email from my inbox and appears only once. It doesn't have any influence on stability in my case.
2. What I think it does is closing
contacts, messages and calendar when other applications need memory. I do
not know if you noticed but once in a while I need to reopen one of these
three applications ater using other memory hoggers.
Well, to be honest the error did, till now, NOT come back any more.
The only thing I changed where some things in Taskmanager, and I am absolutely not sure if that has to do with it. I stopped the automatic memory compression. ( With 4,13 anyway not so uselful any more?)and I disabled some shortcut keys. But I cannot see that that has anything to do with it.
Yes I remarked that closing of software. very handy! The memory really is much larger and more efficient. A great improvement.
And no more spontaneous resets!
I only had the idea that a wrong " missed call" came in when I was downloading mail. That person said he did not call me at all, while de day before I had a real missed call from him.
Brings me to some weard behaviour of the log program, but also that may be my great fantasy.
I am really happy with this upgrade.
Huib
