I see many of your readers are interesting about medications and medicines, so now I going to touch that theme
information about medicines
What is diazepam?
Diazepam is in a class of drugs called benzodiazepines. Diazepam affects chemicals in the brain that may become unbalanced and cause anxiety, seizures, and muscle spasms.
Diazepam is used to relieve anxiety, nervousness, and tension associated with anxiety disorders. It is also used to treat certain types of seizure disorders and muscle spasms.
Diazepam may also be used for purposes other than those listed in this medication guide.
How should I take diazepam?
Take diazepam exactly as directed by your doctor. If you do not understand these instructions, ask your pharmacist, nurse, or doctor to explain them to you.
Take each oral dose with a full glass of water. To ensure the correct dose, measure the liquid forms of diazepam with a dose-measuring spoon or cup, not with a regular table spoon. If you do not have a dose-measuring device, ask your pharmacist where you can get one.
Your doctor or nurse will give you detailed instructions for administration of the Diastat rectal gel. In general, application of the rectal gel is as follows: � Remove the protective cover from the medication syringe and lubricate the rectal tip with lubricating jelly. � Turn the person on their side facing you. Bend the upper leg forward and separate the buttocks to expose the rectum. � Gently insert the syringe tip into the rectum. The rim should be snug against the rectal opening. Slowly count out loud to three while gently pushing the plunger in until it stops. Slowly count to three before removing the syringe. Slowly count to three and hold the buttocks together to prevent leakage. � Keep the person on their side facing you, note the time the medication was given, and observe the person for signs of seizure, skin color, breathing, or any unusual reaction.
Another medications are
Alprazolam is used to treat anxiety and panic disorders attacks, Anxiety disorders are characterized by unrealistic worry and apprehension, causing symptoms of restlessness, aches, trembling, shortness of breath, smothering sensation, palpitations, sweating, cold clammy hands, lightheadedness, flushing, exaggerated startle responses, problems concentrating, and insomnia. Panic attacks occur either unexpectedly or in certain situations (i.e. driving), and can require higher dosages of alprazolam.
Norco is prescribed for moderate to moderately severe pain. This is available in tablet, capsule, and liquid form and is taken every 4-6 hours by mouth.
The Lortab is prescribed for moderate to moderately severe pain. Hydrocodone binds to the pain receptors in the brain so that the sensation of pain is reduced. care must be taken to follow the doctor's instructions when taking Lortab.
Tylenol #3
Codeine is a prescription strength narcotic pain reliever and Tylenol is a
very effective over-the-counter medicine. .
If you want more information you can go to www.crdrx.com , 10/325 at www.10-325.com , Vicoprofen, www.1vicoprofen.com and Lortab, www.1lortab.com.
