Anyone use a bluetooth keyboard withe the N95?
10 replies · 3,847 views · Started 18 April 2007
I'd say it all depends on when/where you plan to use it. Those laser ones really need a perfect flat serface like a desk. Also, bright light (direct sunlight for example) can make it hard to see the keys.
They are cool and if you plan to use it in an office or at home then go for it but if you want to be able to use it out and about you might have trouble.
Thats good to know! One place i can use the TV out is in the car you see and obviously with the windows sunlight is an issue... Looks like it gona be a folding one then! Anyone have one? Should i go for the Nokia one or one similar and half the price?
Wez69 wrote: Should i go for the Nokia one or one similar and half the price?
I have the Nokia one and it works fine, a little cramped because of the limited number of rows but one can get used to it surprisingly quikcly. Also means that you have to use key combinations for numbers which I still struggle with. Having had a bit of a moan I will finish in positive mode; the Nokia one comes with a collection of dedicated blue keys (right and left soft buttons and middle button on cursor and menu) on the lower right corner with these and the arrow keys you can control and access just about everything on the phone. Superb and I wonder if other boards would do this so well.
The nokia one does sound good there! I have found a couple other examples...
Notice the Nokia Menu Key on the "Windows" key. Could be designed to control Nokias?
http://cgi.ebay.co.uk/BLUETOOTH-WIRELESS-KEYBOARD-FOLDABLE-NEW_W0QQitemZ160104987933QQihZ006QQcategoryZ48676QQrdZ1QQcmdZViewItem
Or this one?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=004&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=140106889836&rd=1&rd=1
Not sure on the shortcut keys on the fabric one tho?
I'm not sure yet that I can justify spending �65.00+ on a Nokia keyboard. :con?
I've used a non-nokia bluetooth keyboard from Think Outside, and I think it's great. Used mainly when travelling, on holiday or working away, link here: http://www.thinkoutside.com/stowawaybt_product.html
I've not used the Nokia keyboard but it looks quite similar. I've used this keyboard with my N70 last year and more recently on my N95. I'd recommend it!
I've just bought the iGo Ultra-Slim Bluetooth Keyboard and it works using the built in wireless keyboard app on the N95.
There is no N95 driver for the keyboard so the shortcut features don't yet work. It has four rows so accessing numbers requires holding down the Fn key, but this makes it compact.
The iGo keyboard does lock into place, so you can use it on your lap, something a lot of other keyboards (inc. the Nokia one, I think) do not do.
I've just bought a Dell-branded Ultra-Thin Stowaway from eXpansys (here's my post about the special offer), and I really hope iGo releases the N95 app for it as soon as possible - it's a bit of a pain still having to touch the phone to use the softkeys...
Great keyboard, though 😊
