Maps & Tomtom Info
3 replies · 2,615 views · Started 18 April 2007
2 quick things
1. Maps says it take 2 hours to get home when it's an hour journey. Apparently you should try and re-install the maps service, nokia told me today that sometimes the donwload doesn't complete hence the messed up journey times. Will update you further when i check this out at home later.
2. Tomtom 6 does work on the N95 but obviously you need a bluetooth gps reciever. I can honestly say having dealt with tomtom tech support quite a few times I would not hold your breath on them embracing the internal antenna of the N95. They really are poor.....
Just thought i'd let everyone know
I agree, it's almost a shame that TomTom products are so good cos their uptake of changes and new tech os so poor they deserve to fail! When I got my N91, I found out there was no Version3 compatible series 60 tomtom and 6 months later when it did become available it still didn't work on the N91! In the end I just kept on using my 7610 as a dedicated satnav device
