HI!..
Here i am posting some data that i have about sizes for images
that i think you want to know or you arleady know...
Wallpaper Size: 174 x 132 (remeber that you can delete the image that you use to make the wallparer after you make it, just if you want to save memory.)
Thumbnails size (for contacts): 40 x 48 ... it's much better if you make a pic exactlly of this size on Photoshop or something... then you save that with the best quality posible (bmp for example), then use that pic on the nokia to make the thumbanil for the contact, and then you can delete the bmp file (to save memory). The conversion for the thumbnail is much better and look better
Operator Logo Size: 74 x 14 ... same thing... this image can be a really nice full color image that you can make at this size on Photoshop (or any image editing program), then save that at the quality you want to see on the screen of your 7650, and use that pic to make the OpLogo with SeleQ for example (is the only app for 7650 that i know to do that).
Well .. hope you like it this data...
cya...
BTW!... this is how i look by now 😃
[/img]
Just for fun... will be nice to see other Nokia 7650 users how they
have their Desktop 😃
cya!
Alejandro
Come on!.. don't be shy...
Post your looking 😃 hehehe! ..
cya!
Alejandro
There's already a thread about screenshots... http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3895
yep, alejandro, check out that thread from hankman for the great screenshots. and FYI, the oplogo size, from what i know should be 97 x 25, and there are a lot more apps to set the oplogo. there's efileman, seleQ (of course), fExplorer (by our very own domi) and if im not mistaken system tools as well. just so you know. 8)
ps: why dont you register and join us, alejandro!? 😃
[quote="AEFOX"]
cya!
Alejandro[/quote]
Hi
How did you make those lines Green??????
did you mean the color pallette crypto? if that, just go to tools, settings, phone, display and change the color pallete. hope that's what you were asking. 😃
How about that 'Alejandro' word? That font is nice too. How can the top be personalized? All I see is my network name...
Please, use the
Search Thanks. (normally found on upper right side of screen 😉 )
You can find many usefull things that way, or try the 7650 FAQ:
http://www.allaboutsymbian.com/support/directory/viewcat.php
