This is an automatic post from SpamBuster. The following spam post has been detected:
krisse wrote:"1) How is the sound through the speakers?Is it as good as the 6233?"I don't have a 6233 so I can't compare them directly.
This was actually the first phone I've used that has built-in stereo speakers so it's a bit difficult for me to judge how good they are as phone speakers.
They're certainly better than the mono speaker you get on most phones, and there are some very interesting 3D sound effects that the 6290's audio software allows you to do, such as stereo widening (where the music sounds like it's coming from around you), many types of echo (which simulate being in places like large rooms, alleys etc) and 3D ringtones (where the ringtone seems to float around you. You have to be in the right position to appreciate these special effects however, just like you do with full size hi-fi speakers.
However, speaking personally I've never really seen the point of expensive built-in phone speakers. Built-in speakers are never ever going to be as good as separate speakers, and if I'm at home I usually just plug the 6290 into my hi-fi or computer speakers instead of using the built-in ones. If I'm not at home I listen through the headphones. I guess I'm not the target market for built-in stereo phone speakers! 😉
"2) Does is support A2DP +EDR (Stereo sound over Bluetooth)"
According to the official tech specs, yes, it supports the bluetooth 2.0 headset profile. However, I haven't had a chance to test it with bluetooth earphones yet so I can't comment on how this works. I'll try to test this feature in the review.
"3) How heavy is it?"
As stated above, it's 115g.
In human terms, it feels very light and easy to hold when open, and it's very useable in the closed position too if you just want to use it as a music player. This is a good general design for music phones IMHO, simple external controls mean you can operate the music player without taking it out of your pocket or bag.
"4) The second picture shows what i think is a 2.5" jack?Does it have the pop-port connector as well?"
I'm not quite sure which picture you're talking about, but there's a 2.5mm jack at the back of the 6290 (I didn't take a picture as it's covered by a spring-loaded panel when not in use), and there's also a recharging jack at the back too (again, covered by another spring-loaded panel). I'll do some photos of these in the review.
There's no pop-port, all PC connections (PC Suite, Data Transfer etc) are handled by the mini-USB port under a panel on the right side of the phone. You can just about see the USB logo in this photo:
http://www.allaboutsymbian.com/images/features/1article6290side.jpg
For those who don't know, Mini-USB cables have a normal-size USB connector at one end (which plugs into your PC or whatever), and a smaller USB connector at the other end (which plugs into your phone or whatever).
Personally I think this move to the USB standard is a really good thing, USB cables are so much easier to plug in than pop port cables, and you can use standard USB cables even from non-phone devices such as digital cameras if you lose the one that came with the phone.
Obviously people who have already bought pop-port accessories are going to be annoyed, but I think it's worth it overall, just as the migration from MMC to miniSD and microSD was worth it.
To view this post please visit:
http://www.allaboutsymbian.com/forum//forum/thread/58850/#post308873
Rules matched:
Total score:
